    Mar 2012
    tintagel cornwall
    1,507
    Setting etb speedo
    Hi haa anyone got the settings for the etb speedo running off the following, i have a dax with 17 '' wheels 3.54 dif with the senso on the dif prop flange reading off all 4 bolts.
    Thought would ask before i attempt to work it all out myself from the instructions thanks
    Dax 427 kit collected end april 2012, IVA pass first time 6th May 2014.
    STOKE ON TRENT, U.K.
    10,171
    Try about 11,050 pulses. Should do it
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Low Volume manufacturer of
    OEM style stainless SIDEPIPES
    Mar 2012
    tintagel cornwall
    1,507
    Thanks dave will set to that , just seats n carpet to finish decide which harnesses then triple check everything and book iva., what do you suggest about the sidepipe ends re iva radius .
    10,171
    Call me for the inserts for the exhausts.
    You can borrow them
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Mar 2012
    tintagel cornwall
    1,507
    Thanks will do once get a date, would be appreciated, do i need to do anything else to lower the noise ( sbc). Thanks
    10,171
    Hifihedgehog has just gone through the test with them fitted, but he also fitted some additional sound deadening. I think they can be found on ebay "db killers".
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
