Seat will be easiest, if it has AK seats then the seat cushion is lifted away and underneath are four bolts which go through the floor. Undo these, place the seat where you want it and re-drill the holes using the seat as a guide, re-bolt it down and fit the seat cushion and job doneIf it is an aftermarket seat, it will still be bolted down through the floor so the process will be similar with un-bolting and moving but marking where the new bolt holes go may be slightly more difficult. HTH
