Results 1 to 10 of 30
Thread: Side vents
    Mar 2012
    tintagel cornwall
    1,509
    Side vents
    Anyone know are the dax supplied stainless side vents iva friendly? Been checking over everything and am concerned they wont be acceptable,
    Dax 427 kit collected end april 2012, IVA pass first time 6th May 2014.
    Mar 2014
    Marham
    237
    From what I've read, if the fins are folded back 180 degrees and no more than 40mm apart then they'll be ok?
    http://www.cobraclub.com/forum/gener...ide-vents.html
    Hope this helps?
    Buckingham
    1,609
    If the blades are single cut from 2mm sheet then no if folded sheet with a round edge yes. Never seen any main stream manufacturers do those. I took mine out and put a simple Ali blanking plate mounted at the back of the recess. Some testers will accept small rubber u strips on the edges of each blade. I didn't want to risk it,as the vents are a bitch to take out especially the o/s on the AK and you wouldn't pass with just the hole.
    Rog
    Quote Originally Posted by david hemmings View Post
    AK 427 SC now sold. New ride is a 57 Chevy Bel Air Big Block 454
    Mar 2012
    tintagel cornwall
    1,509
    Hi rog. They are folded but not sure are rounded enough think is only 1 mm stainless so when folded maybe not quite rounded enough is borderline i think
    Buckingham
    1,609
    Hi David
    Extract from manual P16 'Grills, gaps, slots, recesses & holes which have a width of more than 25mm & up to 40mm determined by the contact of a 100mm sphere must have a radius of at least 1mm, more than 40mm then 2.5mm radius'
    As you say could be borderline depending on your spacing's.
    Have you got a date yet ?
    Rog
    Mar 2008
    Coventry
    2,356
    They will be fine, don't worry
    AK, on the road Oct 2012
    Mar 2012
    tintagel cornwall
    1,509
    Hi paul did you go through with them ?
    Thanks rog read that but couldnt determine if met the criteria maybe being paranoid, iva is 6 th may.
    Mar 2008
    Coventry
    2,356
    I went through with the Dave Brookes ones and they are folded in the same way as the Dax ones, as long as the edges are folded you will be fine
    Buckingham
    1,609
    Hi David
    That's why I chose to fit the Ali plates. I do know AK put cover strips on theirs for IVA. I think Paul may have the Cobra Tone fabricated special vents, which I believe are folded.
    Good luck for the 6th, it really is no big deal as long as you have digested the manual and applied the rules. Mine was all over and done in 3 hours and a first time pass.
    Rog
    Feb 2013
    London
    72
    762
    If you haven't fitted them yet get the Dave brooks ones as they are SOOO much better!!
