Results 1 to 10 of 25
    Devon
    281
    Anyone running their cob without a heater?
    Hi All
    My heater hose just gave out, before I replace it, is anyone else running their car without the heater connected? It always seems to me there's enough residual heat from the engine to keep you warm.
    Or does the extra rad in the heater help keep the cooling under control.?
    Geoff
    Buckingham
    1,609
    Wouldn't be without mine it's lovely on those cold February mornings. I do find my temp gauge drops slightly when I switch the fan on.
    Rog
    Quote Originally Posted by Mitch View Post
    Hi All
    Geoff
    AK 427 SC now sold. New ride is a 57 Chevy Bel Air Big Block 454
    Nov 2006
    Shropshire/Wales Border
    50
    6,039
    Yep, if you use the car on cold crisp mornings its a little godsend to be able to warm you a little
    Lloyd B
    9,592
    Agree with the others wouldn't be without it on a cold morning.
    Jun 2013
    Margate
    500
    I'm a heater virgin, having used my car for many years without one. In the summer I found a heater was likely to be a pain, in the winter, it would have been welcome.
    I must confess that the ability to clear the windscreen of ice on the inside when passing over the French/Italian Alps at 3am would have been welcome function, hence I have now included a heater in the latest rebuild/refurb. I also no longer fancy wrapping up like the Michelin man, and wearing the wife's headscarf. I do intend to fit isolating valves however, as the passenger footwell will no doubt become like a fan oven during the warmer months. And no doubt the Chevy block heaters will add to the ability to have warm air from the off in winter.
    3,754
    Quote Originally Posted by chillidoggy View Post
    you won't need the isolating valves to stop the flow of warm air.....no air flows through the matrix until you switch the blower on.
    rgds
    Jun 2013
    Margate
    500
    Yes, Jim I am perfectly aware of that.
    However, the heater matrix, and hence the heater casing itself will reach the same temperature as the coolant, and radiates heat into the footwell. Which co-incidentally is about 150mm above the passenger's tootsies...................
    Lutterworth
    3,388
    No heater here.
    Heaters, Pah! Cobras are supposed to be mens' cars, but you've all turned into a bunch of softies.
    9,592
    Someone on here came up with a great idea of running the fan in reverse to help matters. 6
    8,545
    Quote Originally Posted by FatBoy View Post
    No heater here.
    Yet you still have one Paul
    BIG TONE
