Spring compressor for canted valve heads (351c etc.)
Looking like I might just order one from the 'States with the next inevitable Summit order, but does anyone know of a spring compressor that can be obtained in the UK at a reasonable price, and used with the head in place ie. a lever-type or a spring grabbing type, and which works well with the Cleveland in particular?
Crendon CR427 No. 55
I remember Kaase saying to build a 400+ HP Cleveland you "use good parts and then starting pulling plug wires 'till you get there"...
Ok... just ordered one from Summit :
http://www.summitracing.com/parts/sum-906784
As I need to change the springs with the heads in place, hopefully this'll do the trick!
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
