Results 1 to 10 of 15
    Chadderton, Nr. Manchester
    1,902
    When life knows to kick you down!
    Put my foot on the pedal and it collapsed to the floor, limped home in second:
    The Rover V8/LT77 piston's plunger had snapped in the arm - I'd hoped it was going to be a simple fit a new one but the clutch arm is loose in the bell housing
    Is it as I suspect engine out to refit the lever arm ?
    Jon
    Oh crap...the wife has realised there is no such thing as a 5 minute job !
    8,544
    Hi Jon, I have, in the past, managed to undo the belhousing and pull it away just enough to get my fingers in and refit the clutch fork without completely removing the bellhousing. Very, very tight though!
    BIG TONE
    1,368
    He's only got little girls fingers so he should be fine.
    Rob
    8,544
    Quote Originally Posted by robcob View Post
    Rob
    If that's the case Rob, he won't need to move the bellhousing at all
    BIG TONE
    8,046
    There are a few issues with the standard setup, the clip that holds the arm onto its pivot can be loose which means that the arm falls off the pivot, when I ran with this setup I 'tweaked' the spring clip so that it held the arm in place much more firmly. Another issue is that some of the pivots have a hole right in the middle of the ball end, maybe this was to hold grease or something but it means that the ball end digs away in the 'socket' of the arm, this makes for a rough action when the arm moves. I filled the hole in with weld and ground it back into a ball shape. Any roughness in the socket can be smoothed out with a burr followed by wet and dry. According to JE the pivots also bend!
    You can get extra strong arms off ebay but really they are just a standard arm with a few bits of steel welded to them in varrious places.
    1,368
    Its been a long time since he's had his fingers in a tight little hole
    Rob
    Mar 2005
    1,132
    He needs a gynaecologist. Might cost a bit more than a mechanic though
    David (AKA Firestarter29)
    1,789
    Yes, I've heard they can decorate the hall, stairs and landing through the letter box so should be able to do that little job!
    Mar 2005
    1,132
    or professionally speaking rollerball resection of the endothelium...
    There's plenty I could say to that Dek, but a) it would be professional suicide b) Many of them locally are excellent and c) *** **** *** may have ******* ***** ** !!
    1,902
    I might just bite the bullet and drop in my spare 4.6 lump instead... Roooooobbbb.... you busy ?!?!
