Results 1 to 10 of 21
    Feb 2006
    Newcastle upon Tyne
    129
    Sumo petrol tank query
    Is there a minimum amount of fuel required to cover the fuel pickup inside the tank? I can start the engine direct from a jerry can so I know everything works. I've put in 7 litres of petrol and the pump doesn't pickup the fuel from the tank. I've poked a wire through the inlet pipe so there doesn't seem to be a blckage. Hmmm bit stumped.
    Any ideas?
    Cheers Malc
    In vino veritas
    8,527
    Why not put more fuel in and try?
    Newcastle upon Tyne
    1,865
    Quote Originally Posted by malcolmbuck View Post
    . . . . . .I can start the engine direct from a jerry can so I know everything works. . . . . .
    Have you started your engine!!!!!!!!!!!!!!!!!?
    Newcastle upon Tyne
    1,865
    Malc,
    Apologies for previous post, the shock was too much!!
    Did you prime the fuel pump - although if you started the engine (can't believe you did that without the "Garage Meet" crew there to laugh, sorry help!!) from a jerry can the the pump must be primed and working.
    It could be air in the feed pipe & / or hose from the tank. From memory when I filled the fuel system I used a small funnel to fill the fuel hose, that connects the tank to the pump, before connecting it to the copper pipe from the tank. This, I think, helps the pump draw the fuel up out of the tank and will prevent air locks.
    Having said that 7 litres (about a gallon in old mioney) is not a lot and it may not be reaching the pipe. As Tony has suggested try another gallon, at least, and try it again.
    Good luck & let me know when you are starting it up again - did you get the side pipes sorted or are you on open headers?
    Ian
    May 2008
    Costa del Newcastle upon tyne
    1,980
    How very inconsiderate of you Mr Buck
    We could have all come to help/get in the way and generally annoy and make jibes at you.
    Was it like loosing your virginity?
    Noisy, over to quickly, some family members watching, a bit grin from the excitement, the neighbours complaining because of the noise, then just needing more juice to go again. Hehe
    Did you film it??? (Engine start, that is?)
    Aug 2011
    East Sussex
    68
    15,858
    Check all the connections from the tank to the pump Malcolm. The slightest looseness can induce air under suction and the pump won't prime!
    Chris
    Ex AK427 351Cleveland T5WC
    Feb 2006
    Newcastle upon Tyne
    129
    Well I sort of got carried away and just went for it. Started first time and sounds great. Found the odd coolant leak but sorted it. Yes I was thinking just add more petrol but I'd thought I'd ask the question. The repacked sidepipes sound a lot quieter than Mr Cs that certain Sunday morning. Set next doors dogs off though heehee!
    Cheers Malc
    In vino veritas
    Newcastle upon Tyne
    1,865
    Malc,
    I feel the need for a "Garage Meet" coming on - or even a "Garage Crawl". Malc's first to hear his engine then Tommy's to see the finished paint job - if it is blue with white stripes I am going straight home to weep.
    Anyone around during the week or busy this weekend?
    Ian
    Feb 2006
    Newcastle upon Tyne
    129
    Ian, I'm away this coming weekend but can make after work say Tuesday, Wed or Thursday?
    What a sound burble roar burble oh yes!
    Malc
    In vino veritas
    May 2008
    1,980
    Yay!!! Mid week meet!!! Whoop whoopp!!!
    Im fairly flexible (not literally) I'm at graft most weekdays till 3pm but not this tuesday or wednesday. Off the weekend also!
