Results 1 to 10 of 20
Thread: LS3 Plumbing
    2,368
    LS3 Plumbing
    Does anyone have a schematic of how to plumb up an LS3 engine in an AK? Or photos or ANYTHING !!?
    Apr 2012
    Wrexham
    575
    Dont know if this will help but when i did my LS1 i found this website helpful for pictures etc
    Pirate4x4.Com - The largest off roading and 4x4 website in the world.
    GAv
    AK Ls1/t56
    Body on April 2014
    Passed IVA March 2017
    Registered April 2017.
    2,368
    Thanks Gav.
    I found that today too with Google.
    Looking at the bits I have, I think.....
    The header tank connects to the top radiator hose and the water pump feed on the engine.
    The small pipe on the back of the header connects to the vent pipe on the passenger side head.
    The small pipe on the front of the header connects to the vent pipe on the top of the rad.
    The two pipes near the thermostat are the flow and return for the heater.
    The bottom rad outlet needs to connect to the thermostat housing.
    Can anyone confirm?
    Jun 2012
    West Ewell, Surrey
    486
    I don't have the ak header but what you have sounds correct,
    One thing ref, the heater connection the 19mm (3/4) is the return from the heater the 16mm (5/ is the feed to heater.
    Not sure if any one has experience when using the vw heater with a valve if it should have flow all the time and not just when the heater is on hot.
    I have connected my header to the heater return I.e the header feeds the water pump when the heater valve is closed and the steam pipe from the heads and the rad make the circuit.
    Neil
    Build Started 24/02/13 IVA'd 16/10/2014 registration completed 26/11/2014. First drive 27/11/2014
    Dec 2013
    Newark, Notts
    71
    1,654
    You are welcome to come and check out my LS3 in an AK this coming Saturday. Pm for address if you fancy a trip
    2,368
    Thanks for the offer Charlie, I'm very tempted, but I think the four hour round trip will prohibit the journey.
    If for no other reason than it is four hours away from the garage.
    AK have confirmed my water circuit is correct so I'm ok at the moment.
    2,368
    If I am correct two of the three pipes on the air filter extension tube need to go the rocker cover breathers, are these they??
    Rocker Breather Photo by craigrperry | Photobucket
    Jul 2013
    Bristol
    316
    Craig, did you get the LS3 hose kit from AK or did you source the bits individually?
    2,368
    Quote Originally Posted by Mwalker56 View Post
    All from AK, mines all plumbed up now waiting for heater, also need some more hose to connect 1 rocker breather and the idle control motor.
    Jul 2013
    Bristol
    316
    Have you got any photos of your completed plumbing? I'm just tackling mine at the moment and am almost there. I'm just stuck at the three connections on the stainless air filter extension. Am I right in thinking two for the rocker breathers (as you have suggested and shown in photos above) and then third for the idle motor?
    Mike
