Results 1 to 10 of 10
    Apr 2007
    Shepton Mallet,Somerset
    52
    1,621
    PCV Valve making noise
    Is it right for the PCV valve to make quite a loud ticking noise?
    I took it off to check it and the middle/inside bit is loose? But only passes air one way, so I guess the valve is working.
    Thanks Mark
    DAX with 4.6 RV8 re-built in 2014 using all new bits.
    Oxfordshire
    68
    1,683
    It has a plunger inside which will rattle if the assembly is shaken, but in my experience loud ticking in operation isn't normal - but I've no experience of the RV8.
    The plunger relies on oil mist from the engine for lubrication - so you could try squirting a little engine oil into the PCV valve to see if that helps. They're cheap enough to replace, so I suggest that's your next step. Otherwise, it suggests there's excessive pulsing on the vacuum signal.
    Alan
    Dax 427 DeDion - SOLD
    Apr 2007
    52
    1,621
    My vacuum at tick over is 22Hg. This has been confirm on 2 x gauges. When I Rev it goes down to 5 hg.
    What would cause high pulses?
    I will ask JRV8 to send me another.
    Thanks Mark
    Oxfordshire
    68
    1,683
    Mark,
    It's not a problem I've encountered encountered personally. If there's an oil catch can or anything else in the PCV circuit you could check those. Has the problem suddenly started? Are there any other symptoms - misfires, erratic idle, etc? In my experience, many problems with these old V8s turn out to be pretty simple - so I suggest you whack a new PCV valve in there and then see if you still have a problem.
    Alan
    south wales
    1,019
    Id research that oil catch tank you have installed, im not sure its needed and may affect the pcv circuit operation.
    Oxfordshire
    68
    1,683
    OK, if there's a catch tank then you need to check that out. I have one on my SBC stroker - there was so much churn from the stroker crank that without the catch tank I was getting too much oil entering the inlet manifold. I have mine fitted between the carb PCV vacuum take-off and the PCV valve. Mine wasn't vacuum tight when I bought it, so I had to take the top off and put silicone sealant around the flange to seal it. You obviously also need to empty it from time to time - if it has filled up with oil then the PCV valve wouldn't be seeing the inlet vacuum properly.
    Alan
    Jul 2001
    71
    13,455
    Not being funny, but are you sure it's the PCV valve and not a tappet.
    Mike
    Cobraless
    Life's good, live it.
    Apr 2007
    52
    1,621
    Yes Mike, when I pull the hose off, the ticking stops. Definitely the valve. Also I have listened to the engine with a stethoscope, all quiet, no ticking.
    Plumbing is PCV valve to catch can, the out of can to front of carb vacuum port.
    Oxfordshire
    68
    1,683
    Mark,
    It looks as though yours is the same catch can as mine. I blocked one port and blew into the other, and discovered it wasn't air/vacuum tight. Suggest you test yours, and if air escapes remove the top and smear silicon sealant all around the join.
    Alan
    Jan 2008
    Basingstoke
    1,125
    The PCV on my 4.6 does the same thing, but I dont have a catch can - connects straight to the front of the carb. Had a look and it doesnt appear to be faulty - I'll try replacing mine too.
