Results 1 to 4 of 4
    Sep 2005
    Alfreton, Derbyshire
    71
    Part built AK generation 1 for sale
    Reluctant sale of AK generation 1 kit.
    Chassis:
    Lovingly reconditioned Jag XJ6 running gear (every bearing, nut, bolt, washer and bushing replaced not some half baked job)
    Brakes and wheel hubs fully reworked by Wards, new disks and pads all round.
    Clutch and Brake lines and fuel pump all fitted. Fuel lines fitted but need connecting to fuel tank and inlet manifold.
    6 adjustable coil over dampers fitted (will need setting up for your preferred ride).
    Fixed geometry checked by AK but will still need the front end tracking.
    Full under-slung stainless exhaust system manufactured by AK (includes Lambda sensor in each side).
    Rolling on build wheels.
    Body:
    Fitted to chassis, this was one of the first out of the new mould back in 2006 (gel coat is Brunswick green)
    AK pedal box, BMW steering column and handbrake fitted.
    Power Unit:
    Fully rebuilt 3.5L Rover V8, hot washed, re-bored and honed, new pistons and rings,
    fast road cam, new timing chain, all new bearing shells and seals and all held together with ARP studs.
    Heads skimmed to accommodate composite gaskets, lead free valve seats fitted, new valve gear fitted (including valve guides, rockers, posts and rails).
    Fuel injectors professionally serviced (ultrasound cleaned, new filters etc).
    Drive Train:
    SD1 5 speed manual gearbox with transducer type sender (professionally rebuilt).
    3.31 Diff (professionally rebuilt by Russell Ram).
    New lightened flywheel.
    New Clutch assembly including pressure plate and thrust bearing and new slave cylinder.
    Cooling:
    Remanufactured SD1 radiator.
    16" Passet Electric fan fitted with inline variable temp sensor.
    Shiny stuff:
    Stainless header tank.
    AK manufactured custom dual filler stainless fuel tank fitted with diptube rather than swinging arm sender.
    Full stainless engine bay cladding.
    Dual 3 leg roll bars including escutcheons.
    Twin Brasscraft Aston type fillers with unleaded rings fitted.
    Electrics:
    New Distributor and Coil.
    New Alternator.
    New High Torque starter.
    Partially fitted AK wiring loom (includes wiper module for BMW column).
    Headlights, number plate light, ignition key switch, battery isolator switch, dash warning lights.
    Wiper mechanism includes 3 boxes, motor, tube and cable (but not wiper arms).
    5 clocks and associated senders (oil pressure, fuel, temp, tacho, odometer (odometer is of the electrical calibration type so you can tweak it during the IVA)
    Misc:
    Full set of gas rams and stainless brackets for fitting to the bonnet and boot.
    Boot interior hinges.
    Fuel pipe protectors x 2 (fit in boot to protect pipe from fuel filler to tank from damage)
    Washer bottle.
    Rover workshop manual
    Haynes Rover manual
    Haynes Jaguar manual
    Includes Donor V5, currently sorned.
    Around £20K of build receipts, build photos available to help with registering.
    Serious Offers in the region of £10K please.
    I can guarantee I've forgot to mention something so feel free to call to discuss. Contact Chris on 07528 462936 if interested.
    Sep 2005
    71
    On hold pending payment.
    Jul 2013
    Reading Berkshire
    66
    Hi
    Did the sale go through or is it still available?
    Jeff
    Sep 2005
    71
    This is now sold. Thanks to everyone who expressed an interest.
    Chris
    AK Kit ARRIVED!. The garage is now full of usefull stuff rather than stuff she didn\'t want to throw away, thank you Loscoe tip.
