    Apr 2015
    34
    583
    H Gate Gear plate
    This might rub the traditionalists the wrong way so apologies in advance,
    Anyone fitted H-Gate plate to the gearstick like in Lambos or Ferraris, any idea where to get one from?
    Dec 2014
    Sherborne, Dorset
    99
    I'm a traditionalist...... but try Hill Engineering http://www.hillengineering.co.uk/cat...gates-c-3.html
    Might be tricky to set up though as I expect the throws are quite different.
    Bill
    Crendon Chassis No:13
    Jan 2009
    Dronten, the Netherlands
    347
    Agree with Bill, I think the only way is to work out all measurements and either build it yourself or have a one-off special from a construction company. Looks superb, not sure about compatability with Cobra interior though..
    Theo
    Not for the faint hearted, not for the shy...
    Nov 2006
    Shropshire/Wales Border
    5,955
    Very easy thing to make with a milling machine, but agree with the others, could be much harder to set up so it works cleanly every time. Might be worth making some kind of thick card template to get something that works.
    Bear in mind gearboxes move slightly as you drive, so consider leaving enough room around it so it doesn't knock you out of gear every time you hit the loud pedal
    Lloyd B
    Apr 2015
    34
    583
    Cheers guys,
    I was thinking about a template first. I'm just throwing ideas around by putting my favourite bits of every car into this build!
    Sep 2004
    Bressingham
    1,343
    It has to be attached to the gearbox to work properly.
    You need a good amount of movement across the gate to allow enough room for the separate fingers.
    We fit them to the DBR"s and they tricky to get right.
    A
