Results 1 to 7 of 7
Thread: Spax or Gaz
    Jul 2013
    Hertfordshire
    522
    Spax or Gaz
    Is there a great deal of difference between the two? I need 4 rear coilovers for my Unique Autocraft Python.
    9,586
    These days the majority of the manufacturers seam to go the Gaz route no idea if there better but think I would tend to go with this trend.
    Oct 2006
    Toton, Nottinghamshire
    888
    I replaced my Spax coilovers with Gaz ones some years ago. The Gaz ones had more scope for adjustment and were a better price. If I remember correctly you need 3 measurements from your old coilovers - the length between the centres of the mounting bolts at ride height, the closed length and fully open length. Some people have recommended using Avo coilovers too.
    Russ.
    1984 DAX Cobra
    Feb 2003
    Devon
    7,767
    Crendon's have AVO's.
    Excellent quality kit. Probably more expensive than the Spax/Gaz?
    Jul 2013
    Hertfordshire
    522
    Brilliant thanks guys for your pearls of wisdom. I've also been recommended Dampertech so will give them a call.
    Jul 2001
    72
    13,455
    Dampertech are the Gaz shock suppliers
    Mike
    Cobraless
    Life's good, live it.
    Chilwell Nottingham (the nice bit)
    511
    Quote Originally Posted by Boxoftricks View Post
    Dampertech are very good, they will build shocks to your specification. GAZ everytime, IMO Spax are rubbish, having wrecked several on my motor over the past 25 years.
    1985 DAX 427, BMW Black, no scoop, no brightwork, no carpets. 15" Revolution split rims, BFG boots, 3.9 Rover V8 ex Disco 9.35:1 with 4.6 heads, Hurricane cam, Modified SUs and other P6 bits and bobs. SS headers & side pipes, Jag/Jag uprated lowered springs, GAZ shocks, Red Dot discs & pads, Toyota Supra CR high 5th box & special clutch.
