Results 1 to 10 of 14
Thread: Camber setting
    Sep 2014
    birmingham
    40
    Camber setting
    OK - so picked the car up yesterday (7 hour drive) nice!
    I now have the front wish bones etc all fitted - come to set the camber with the piece of paper/string/set screws etc and it all seems a little un-precise....Is this really the best way?
    Im also confused (doesn't take much) by the fact that you put the two set screws in place but why one with washers around it? Depending if you have large or small washers this could alter the angle so seems odd. Is it better to set it another way - i.e. with an iPhone for the angle rather than a piece of paper????
    Any experience of this welcome! I thought I had seen a post about this but couldn't find any.
    Sep 2014
    birmingham
    40
    This should say Caster setting not Camber!
    9,501
    Is this a mk1 or mk2 chassis ?
    Sep 2014
    birmingham
    40
    Its actually the Gen 3 but I'm following the Gen 2 instructions and its pretty similar in this area.
    P
    Nov 2007
    Chester
    614
    check the threads on the site. It's been covered enough in the past. I used 2 rulers at 90 degrees and some string, with a bit of trig. Amazing how accurate it actually can be. I bought a digital spirit level some time afterwards, Checked the setting and the set up was spot on. As I say do a search and all will be revealed.
    Sep 2014
    birmingham
    40
    Yes I have found some...it's not the calcs I have an issue with its the odd bit about washers on one screw and not on the other...
    Once I have an edge to work from I'm sorted.
    P
    Mar 2014
    Marham
    236
    It does seem odd, why not just do without the washers and increase or decrease the angle as appropriate?
    i just made the assumption that an m6 washer was an M6 washer!
    AK Gen II - Delivery May '15
    Sep 2014
    birmingham
    40
    Yer I'll have to do the same....need some washers first. The kit says it has some but they a recall too big.
    Off to the shops then....
    2,208
    I used an app I downloaded onto the iphone instead of the string.
    I did question the accuracy of the app but it can't be any worse than string and a paper gauge.
    New Forest. Hampshire
    406
    If you are settling this up when building the chassis then I would not worry too much about it for now as you will want to revisit it all once the weight is on it and you find the natural ride height and see how the steering feels and how well it self centres. With power steering you will want more caster on than with a manual setup.
    Robin
    AK427
