Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 31
  1. #21
    3,683
    Quite a lot of mainstream cars have electric handbrakes now Myles. I still think you can't have a hydraulic one though but I'm not sure.
    As long as it is entirely separate from the normal hydraulic brake system then it is fine
  2. #22
    8,533
    Didn't know that!
    BIG TONE
  3. #23
    Jan 2009
    Dronten, the Netherlands
    347
    Another thought is what if the battery goes flat or if you park up and apply the handbrake and then take the battery isolator key out. Will the handbrake stay on or does it need constant power to hold the cables.
    I am not knocking the idea, actually its quite the opposite but I am just thinking of the possible problems before maybe implementing the idea myself.
    Anthony, it seems to be a spindle servo, so I suppose it needs power to operate both going "on" & "off". If they are widely used these days, surely the reliability will be OK? Still, the more gadgets you have, the more can get broken, and, more importantly, the heavier the car will be.
    Best Regards, Theo
    Not for the faint hearted, not for the shy...
  4. #24
    Mar 2010
    1,244
    Here are the simple instructions that come with the kit. Hopefully should answer most of your questions and concerns.
    Cheers.
    Paul.
  5. #25
    Nov 2007
    Chester
    630
    Nice bit of kit, I like it. As long as you make the access hatches to work on it when the bodies on it looks good.
    Not sure what the issue is with Ak handbrake set ups, mine works fine. I spent a bit of time getting the route clamped with a reasonable bend radius and also setting the pad levers up when I assembled the calipers.
    I suppose another benefit of using the lexus auto box is that you tend to use the park position!
    Yet another reason for TonyD to espouse the virtues of ls400 transplants!!
  6. #26
    Nov 2003
    West Midlands UK.
    2,995
    Quote Originally Posted by alunwill View Post
    Who me??????
    Must resist,.......... must resist............
    Tony
  7. #27
    Sep 2013
    Pontefract
    497
    I've just ordered one of these too
    Having spoke to them the unit conforms to IVA as the requirement is
    "An electrically operated parking brake switch must be protected from inadvertent use. As an alternative, with the ignition off, the switch must be capable of applying the brake, but must not be capable of releasing the brake."
    Which is exactly how the switch system on this kit works.
    basically loss of power it just doesn't move so should it break you would need to remove the clevis or unbolt the unit from the chassis to release the pressure. No big deal depending on where it is mounted.
    The only thing to do now is find a nice looking switch to use it with as they said "it comes with a switch but you'd probably want to replace it with a nicer one"
    AK GenII, collected 11th September 2015, passed IVA March 22nd 2017, On the road Friday 28th April 2017.
    LS6 468.4 bhp, 440 ft/lbs on the Dyno
    Canems ECU
    Blog: http://markscobra.blogspot.co.uk
  8. #28
    Buckingham
    1,609
    Why would you want one ! I hate mine on the tin top.
    Rog
  9. #29
    Sep 2013
    Pontefract
    497
    Quote Originally Posted by Roger Shackleton View Post
    Rog
    I love mine in the mondeo. For me it just provides a modern upgrade to a classic looking car which is exactly what I wanted to achieve. It probably comes from working in technology.
    Canems ECU
  10. #30
    2,308
    I've just acquired a Hiwin linear actuator off Ebay for next to nothing (no PCB control though, which can be purchased separately I hope). My intention is to make a bracket and retro fit it somehow to my completed AK.
    I'm convinced the issue with my set up it getting the load through the handle mechanism and cables into the shoes, hopefully this should help !
    I'll let you know how I progress (slowly I'm sure).
