Results 1 to 8 of 8
Thread: Rubber Grommets
    Sep 2013
    Pontefract
    497
    Rubber Grommets
    does anyone know where I can get a 1" ID rubber grommet for my ECU wires to pass through the bulkhead. I've searched all over the net and am struggling.
    I'm using a canems ECU - what have others done?
    AK GenII, collected 11th September 2015, passed IVA March 22nd 2017, On the road Friday 28th April 2017.
    LS6 468.4 bhp, 440 ft/lbs on the Dyno
    Canems ECU
    Blog: http://markscobra.blogspot.co.uk
    Apr 2013
    devon
    65
    201
    Hi i have used these people www.vehicleproducts.co.uk they deal with all types of auto electrical and some tools etc as well,really helpful and quick with the postage back to you........Andy
    Nov 2007
    Chester
    622
    check a thread on this site. I published details oof one of the few places that does the size but also the panel depth. Not sure but to memory it may be AES, automotive electrical supplies. If not it is on this site somewhere.
    Aug 2013
    North Yorkshire
    405
    Not a lot of use to you Mark, but this is what I did, I'm also running Canams ECU. I preferred to support it a bit more than just the bulkhead thickness as I felt it might sag over time.
    Hilperton,Wiltshire
    2,585
    Nice looking fittings.
    Sep 2013
    Pontefract
    497
    Is that one of your custom made fittings Keith? If so, any chance you can make me one?
    Canems ECU
    Dec 2005
    leeds
    202
    Just type bulkhead connector into ebay and you get results for over 1700 fittings a couple of types below
    http://www.ebay.co.uk/itm/1-1-4-BSP-...uu_F12SSlPJPWw
    http://www.ebay.co.uk/itm/PM1204E-BU...YAAOSwtJZXW78I
    Aug 2013
    North Yorkshire
    405
    Quote Originally Posted by JordansGhost View Post
    Yes it is Mark, I've got one here but it's got someone else's name on it but I don't think he'll need it for a quite a while, failing that search for 32mm open grommet they "should" have a 25mm bore.
    Or there is Pauls options but I'm sure the IVA inspector will be looking at all cables passing through panels must be fitted with rubber grommets.
