Page 1 of 7 123 ... LastLast
Results 1 to 10 of 70
    Jan 2016
    Long Melford, Suffolk
    591
    Starting in cold weather
    Took the car out this morning for a quick spin as nice and sunny and dry.
    I haven't driven it for about 3 weeks, she was a bit sluggish to start.
    It's been very cold here recently, and I did the normal 3 pumps on the gas before hitting the start button. Loads of power in the battery, starter motor seemed powerful but it took maybe a couple or tries and holding starter button down for maybe 10 to 15 seconds before she fired up.
    Is this normal??
    Cheers guys
    Dax Tojeiro - Mike Huddart 383ci stroker, dark blue with wimbledon white stripes, retro racing decals.
    Feb 2003
    1,060
    Do you have an electric petrol pump, if so wait a few seconds for it to fill the carb. if you have a mechanic pump it will act as you describe as it has to fill the line, then the float chamber before it will fire up.
    Frank Dowsett. BLOKE.
    Hilperton,Wiltshire
    2,600
    Do you have a choke or not. If not it probably will crank over more when very cold. The use of a choke has been discussed on here before. I have one, starts easy in cold weather, many remove it.
    Jan 2016
    591
    Hi. Dont think I have a choke as the bloke I bought it off said it didnt. When I turn power to the ignition there is a whirring noise, the rev counter goes to 6 then back to 0, then I can start the car. Could this be the electric pump?
    When I bought it, the guy was very clear that when cold, pump the gas two or three times before starting.
    Will endeavour to find out next time it goes back to the garage!
    Hilperton,Wiltshire
    2,600
    He was very clear that it was a very well looked after car before you bought it,i think you may disagree ,so it may not start as easy when the weather is very cold. Mine used to be hard to start in cold weather so I put the choke back on.
    How's the oil consumption? Fixed?
    Jan 2009
    blackpool lancs.
    5,092
    Slow to start, is not a problem and is quite normal, every engine will be built and set up differently, and so will start differently too, cold weather will usually mean slower starting, and often less power from the battery to start it with, some fuels will vary slightly in octane, methanol content ect, modern fuels will also go "stale" and be less volatile in a relatively short time when exposed to air as in the carburettor
    Mine has no choke, and has a manual pump, so can be very slow to fire up if its not been used for a while, I don't have a problem with this as I like to leave it turning over till the oil pressure comes up anyway, then with a few pumps, it always starts.
    Sounds like the "whirring" noise is your electric fuel pump, the blip in the tacho is also normal, our cars have personalities, and like us don't like being kicked out of bed on a cold morning! lol, Enjoy
    May 2015
    swansea
    155
    Mine is similar Paul when temperature near freezing . Just needs more pumps of gas before pushing start in my case .
    Sep 2014
    aberdeenshire Scotland
    64
    220
    when cold ( which is all the time in Scotland) we give about six pumps and starts no problem, do not keep starter running just give another couple of pumps and try again. every engine is different, you will find out what is best buy trial and error.
    Shuggie
    8,537
    You kit car guys do crack me up with your quaint starting procedures, I just put the key in and turn it, car starts first time every time!
    Nov 2013
    My Garage
    987
    Well goody for you. We all bow in your general direction
