Thread: Rubber grommets
    Apr 2015
    35
    583
    Rubber grommets
    anyone know what size and where to get the rubber grommets which are fitted on the bodywork around the quickjacks or overridera etc?
    AK Gen II
    Chevy 350
    Tremec TKO 500
    Dec 2015
    Walsall
    153
    Mate you will get some grommets from a electrical supplier they come in different sizes 20mm or 25mm or 30mm, with holes in the centre or filled in. you can then cut what size hole you need, you will be able to get them from Screwfix as well. They are used on back boxes for double sockets. I use them all the while as I'm an electrician.
    Richard
    Jun 2012
    West Ewell, Surrey
    486
    I have used these guys for years for grommets and general wiring supplies,
    http://www.vehicle-wiring-products.eu
    Build Started 24/02/13 IVA'd 16/10/2014 registration completed 26/11/2014. First drive 27/11/2014
    10,009
    The proper grommets for the front at least are specially shaped,
    Although not cheap they are or were available from Finishline Accessories in the USA.
    Must get some myself.
    In build- Hawk 289 Sebring
    Nov 2006
    Shropshire/Wales Border
    6,005
    As Kev says whilst the rear ones are pretty standard the front over riders come through the body where the body is at an angle to the vertical. Finishline do them. I notice Europa now do front ones with a thin inner section to allow flex. Not sure how go they will look in practice but definitely cheaper.
    https://www.finishlineaccessories.co...ets-front.aspx
    Lloyd B
