Results 1 to 8 of 8
Thread: LS3 Oil Change
    2,308
    LS3 Oil Change
    My LS3 engine is due it's first oil change.
    Is there any special procedure I need to follow to make sure the oil pump stays primed?
    My current plan is oil filter off, new filter on, drain sump and refil.
    3,682
    Nothing special, but sequence is:
    Drain oil
    Oil filter off
    Drain plug back in
    Fill oil filter & smear of oil around rubber seal
    Fit oil filter
    Fill with oil to correct level
    Run engine, stop, check oil level & top up as required
    2,308
    Anyone got any idea of the oil capacity of an LS3, I've bought a 5l can but I think I'll need more.
    3,682
    More than 5, less than 10 (can't remember exactly, but defo more than 5)
    GD J1M
    Mar 2008
    Coventry
    2,335
    Pretty sure it is just over 7.5 litres for an LS3
    AK, on the road Oct 2012
    Dec 2013
    Newark, Notts
    69
    1,547
    6.5 litres rings a bell with me
    Charlie
    8,533
    Put 5 litres in and dip the oil, if not to level then keep adding half a litre until it is at level, then run engine till warm, stop it and after ten minutes dip it again and top up as necessary. Once filled you'll know exactly how much oil your particular engine/sump combination takes!
    Dec 2004
    Staines Middlesex / Abu Dhabi
    65
    1,083
    Just do not overfill at the beginning - TonyM method above makes good sense and avoids any spillage or unnecessary smoke !
    You can always top up - but not so easy to remove excess
    Chris Lutman -427SC Coupe / MG Tojeiro "LOY" replica
