Results 1 to 10 of 14
    Dec 2005
    leeds
    183
    Dax windscreen motor position
    Would be interested to hear or see pictures of how/ where you have mounted the windscreen wiper motor in your Dax
    Thanks,
    Sep 2012
    Stoke on Trent
    36
    137
    Not the best photo , but with the bracket from Dax I that attached to scuttle on passenger side & then the motor , but did have to do something to the motor before this , can't remember what it was but I think it was change it internally to run 2 wipers not 3 but it was 3 years ago
    Hope this helps any more pics u might need send me your number will see if I've got it and send them over to you .
    it,s all fun untill someone loses an eye
    DAX de dion build (started jan2013)
    Nov 2016
    Cheshire
    having spent far too long under the dash today I can say mine is under the dash on the drivers side attached to the chassis the windscreen support bracket
    Dec 2005
    leeds
    183
    Thanks for the info guys
    Sep 2012
    Stoke on Trent
    36
    137
    Also my wiring loom connections are that side along with the 1 for the heater matrix
    Cambridge
    33
    1,127
    I found a nice solid bit of right angle bracket and bolted it to the scuttle hoop, then fitted the motor to the bracket
    Dont forget a bit of rubber behind the motor to stop it rattling around
    regards
    Dave A
    9,743
    Mine is very similar to Dave's.
    just mounted to the scuttle tube with a small triangular bracket.
    May 2011
    Flimwell
    537
    I did much the same. Passenger side scuttle hoop fixed with a couple of exhaust clamps. Wiggle everything around to get the optimum position and minimise curves in the drive cable.
    Dec 2005
    leeds
    183
    Thanks for the info guys. Whilst searching the web for other Dax builds came across this small footprint heater http://www.t7design.co.uk/index.php/...eater-12v.html. I am planning to fit just in front of the passenger side scuttle tube which will keep it clear of the passengers feet
    Dec 2005
    leeds
    183
    Just realised its the same/ similar heater matrix shown in Dave A's picture above. Powered it up this morning has a powerful fan for the size of unit
