Results 1 to 10 of 17
Thread: Ak horn earth
    Apr 2014
    Stourport on Severn
    303
    Ak horn earth
    Anyone like to share how they earthed the horn using the steering column shaft? I have continuity from steering wheel boss all the way to the input shaft of the rack - but no further, which suggests there's some non metallic bits in the rack that are insulating.
    Only solution I can think of is some sort of slip ring/ brush arrangement but cant see this up in any threads on here.
    I have the standard E34 column and Ak rack.
    2,368
    I didn't think it was earthed through the rack, I thought it was through the mounting bracket?????
    Touch one end of your tester on your column spline and the other end on the chassis, does it read 0 or 1?
    Jun 2014
    Redditch
    117
    Hi Steve, it doesn't help much but i recently fitted mine. I took the earth direct from the boss which only has contact with the column. There was a good earth from the column and i didn't make any changes to the standard e34 column or fittings.
    Apr 2014
    Stourport on Severn
    303
    Thanks guys, I've tested connectivity between column splines and chassis and no connection. Time to sleep on it!
    just as a guide, does the horn work with the ignition off on the AK?
    Jun 2014
    Redditch
    117
    Hi Steve, mine only works with the ignition on
    Apr 2014
    Stourport on Severn
    303
    Cheers Andy, that makes sense from the fuse guide. The instruction say fuse 6 looks after , horn, reversing lights and indicator/hazard., all fed by ign on. I'll be doing more testing tomorrow but I thought the Hazards needed to operate with ign off?
    Im sure all will become clear tomorrow!
    Southwest, Somerset, U.K.
    37
    3,324
    I have had this problem on an airbag version column.
    Take a piece of wire from bolt to bolt across the Ujs on the lower column shaft and you will have continuity to earth
    So basically a piece of wire from pinch bolt to pinch bolt across the UJ
    Hope this makes sense.
    Dec 2004
    Staines Middlesex / Abu Dhabi
    66
    1,083
    as mentioned - BMW use a rubber UJ in the column - usually it has a wire strap - but not guaranteed. Add a wire link across the UJ to get a ground return.
    Chris Lutman -427SC Coupe / MG Tojeiro "LOY" replica
    2,368
    I think Steve says he has a connection all the way to the rack, ruling out the UJs?
    2,368
    Touch the tester between spline and brackets on the column??
    Mine just worked so this is not a problem I've come across.
