Results 1 to 10 of 11
    Jun 2016
    Nantwich Cheshire
    52
    270
    AK Gen 2 fuel routing under diff.
    I'm just getting to the point where I need to route the fuel lines on my AK.
    I know you need to protect them as they run under the diff.
    However I'm struggling to work out where to mount anything to.
    Also do they just have to be clipped or fully protected with a plate.
    I'm planning on running two lines feed and return, one down each chassis rail.
    If anyone has any pics of a similar installation on a gen 2 it would help a lot if I could take a look.
    Mike
    Aug 2016
    WELLINGBOROUGH
    91
    Hi Mike,
    My diff had four tapped holes on the underside. I got a piece of 5mm plate and fashioned feet welded to the plate and bolted to the diff.
    I then ran the two fuel lines on the plate which was long enough to protect the lines up into the tunnel. I also fitted clips on the plate to hold the lines.
    Hope his helps
    sceptic
    9,450
    I ran both the fuel lines (feed and return) over the top of the diff in such a way that if I ever need to do anything to them there is a joint either side.
    Sep 2013
    Pontefract
    497
    Quote Originally Posted by scepticwoody View Post
    Hi Mike,
    Hope his helps
    sceptic
    Same here but used 3mm stainless. Note though that when the car bottomed out it was the ak tank built in swirlpot that touches the ground not the diff so the plate needs to extend to cover that area too.
    AK GenII, collected 11th September 2015, passed IVA March 22nd 2017, On the road Friday 28th April 2017.
    LS6 468.4 bhp, 440 ft/lbs on the Dyno
    Canems ECU
    Blog: http://markscobra.blogspot.co.uk
    Jun 2016
    Nantwich Cheshire
    52
    270
    I've stuck my head under my diff and can only find two tapped holes of the rather large variety.
    Maybe I can fashion something up to mount off these.
    Are these the holes you guys are talking about ??
    Apr 2014
    Stourport on Severn
    234
    If you don't fancy making one, AK sell a plate including bolts and spacer washers that fits to the 2 holes on the bottom of the diff.
    Jun 2016
    Nantwich Cheshire
    52
    270
    Having done a bit of research I'm not sure about the AK one.
    I think I'll CAD something up that I'm happier with and get one made.
    Thanks for the info though.
    Jan 2014
    Newark-on-Trent
    257
    I went through the diff mounting plate with a bulkhead fitting for feed and return, (I think you can just about see them in the photo), but I still made a plate to stop the fuel tank swirl pot hitting the ground.
    Jun 2016
    Nantwich Cheshire
    52
    270
    That looks like a nice solution. I don't suppose you have the dims of the plate? Is that just a foam pad between the pad and the swirl pot?
    Thanks for the pics I think I'm going to do mine along similar lines.
    Dec 2013
    Newark, Notts
    68
    1,468
    Snap!! Just like mine Lionel! Sorry Incey, cannot find my template. Put it safe somewhere where I cannot find it!
    Charlie
