Results 1 to 7 of 7
    Dec 2011
    Rugby,West Midlands.
    609
    What type of exhaust manifold bolts
    I have taken off the n/s exhaust side pipe in order to get a crack welded up where the collector merges with the large main section. Before I drifted the four pipes off the manifold to separate the system, I checked to make sure all the exhaust manifold bolts were tight in the heads, and they were all a bit loose. I then noticed none of them had any form of anti-vibration washer, which I thought was strange. So I took one out to see if it was long enough to take a spring washer, and the threaded portion is only ¾” long, which has to go through the ¼” thick manifold plate. So I won’t to buy some longer bolts, but I am not sure what type of thread they are.
    My current flanged bolts are plated, 1” long in total, threaded portion is ¾” long ( see attached snap)
    Thread diameter is 0.375”, which is 3/8”, with 16 TPI, and according to my Zeus tables that seems to indicate that are 3/8” UNC bolts….. Am I right?
    If it helps, my SBC is fitted with Patriot heads, which I am hoping take the same bolts as a standard SBC head.
    Should I get stainless steel bolts, to make sure they don’t seize up and should I use spring washers on re-assembly.
    Paul.
    9,511
    Not had any type of anti-vibration washer or gasket fitted in years due to the bolts always going loose and the exhaust gasket blowing. Just use high temp silicon now and in 10 or so years never had a bolt come loose or had either side blow. The only way to go in my opinion. The bolts you have shown are the ones I use also.
    9,916
    3/82 UNC is correct for a SBC.
    In build- Hawk 289 Sebring
    4,010
    Crikey that's small, Kev
    9,916
    Doh! fecking caps lock.
    3/8" UNC.
    Dec 2011
    609
    Thats why i was thinking of using spring washers.
    Thats between head and manifold flange i gather, i want to find a silicone flexible sealer which will withstand temps between 800-1200 degrees,for when i re-assemble the four pipes back into the manifold,as it was blowing slightly before ,so it dont go hard ,crack and fall out.
    Paul.
    Dec 2011
    609
    3/8" UNC.
    Thanks, i now know what sort of bolts they are
    Paul.
