Results 1 to 4 of 4
    Sep 2016
    Newbury, Berkshire
    139
    AK Triple Splitter Fitting
    Hi folks, I have just drilled the holes for the triple splitter and am left wondering if I've done it right. I put the splitter in position as best I could and marked the drill hole positions. However the splitter is not perfectly perpendicular to the nose opening as it was tricky to get the right angle - the lower splitter fin is closer to the body than the top fin. It looks OK though I think. How have others placed it? I hope I have explained this clearly enough.
    Cheers Mike
    1,861
    If I remember the middle fin comes through the opening and I positioned mine so both top and bottom fin had an even (about a 3mm) gap to the shell.
    Biggest issue I had was trying to decide which way up it was supposed to go.
    Sep 2013
    Pontefract
    487
    I've sat mine slightly back and have a difference as you do. See the blog pics - I think it looks fine.
    AK GenII, collected 11th September 2015, passed IVA March 22nd 2017, On the road Friday 28th April 2017.
    LS6 468.4 bhp, 440 ft/lbs on the Dyno
    Canems ECU
    Blog: http://markscobra.blogspot.co.uk
    Sep 2016
    Newbury, Berkshire
    139
    Thanks guys, I think I have sorted it now. Cheers Mike
