Results 1 to 9 of 9
    Dec 2013
    Flackwell Heath
    95
    Ideal boot lock height
    Could some one give me the ideal boot lock height from the bottom edge of the boot please? I realise to a degree its determined by the latch hoop but there's a huge amount of thread ie adjustment on the hoop ( S&J supplied)
    many thanks, Mark
    AK gen2 ls3
    Southwest, Somerset, U.K.
    36
    3,265
    55mm from bottom of bootlid edge to centre of boot lock
    Place boot lock handle gasket on this centre mark and cut accordingly. This should put the centre of the lock handle bar through the double skin area on the right place to hide the latch between the two skins
    Remember measure twice cut once
    Once the lock is fitted get in the boot and mark the required striker position while a friend operates the handle.
    Hope this makes sense and helps.
    9,578
    Probably end up being the same height as Chimeara recommends but I was going to say fit the lock between the two skins so that it looks really good and then adjust the striker accordingly.
    Dec 2013
    Flackwell Heath
    95
    Many thanks for that Anthony! I'll get on to it in the morning,
    cheers, Mark
    AK gen2 ls3
    36
    3,265
    I actually fit the latch on the inside of the boot now rather than between the skins. It S just as nest and a whole lot easier to set up. You may need to adjust the handle height if fitting the latch between the skins so it conceals it properly
    Dec 2013
    Flackwell Heath
    95
    I went 55mm I height as you said and between the skins which seems to have worked out ok, I think I may have to slightly mod the number plate? Into the boot next!
    Mark
    AK gen2 ls3
    36
    3,265
    Yes you will have to cut the number plate around the boot lock or as others have done cut it out around the number plate light at the top. You will also need to raise the number plate light to get the required space for Iva
    May 2014
    770
    Or position the lock just slightly lower to overcome the IVA fail
    Alan.
    AK Gen II on the road Jan '19
    Tremec T56 Terminator.
    3.27:1 Powr-lok LSD
    36
    3,265
    It won't work as there will be nowhere to mount the latch if you mounted it that low
