Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: Heavy Clutch
  1. #31
    9,944
    Not sure about an AK but I and others fitted a remote servo (MGB) on my original Dax. It worked well. The only issue I had was insufficient vacuum in heavy traffic due to my quite radical cam. I fitted a vacuum reservoir too which helped.
    People will tell you that you loose pedal feel by fitting a clutch servo, which is true but I found it perfectly OK and you get used to it quickly.
    1965 Ford Mustang 289 Convertible FOR SALE
    In build- Hawk 289 Sebring
  2. #32
    Jun 2014
    Swansea
    108
    Hi Kev
    Just resurrecting this old thread.
    I am going to fit a remote clutch servo as my clutch is very heavy and due to my knee not being to good it is a struggle in heavy traffic.
    I note you used a remote MGB servo, I was just wondering what ratio it was as I can see on the internet that there a few variations 1.65, 1.9, 2.3. Correct me if I am wrong but the higher the ratio the easier the pedal should be.
    I note you mentioned the insufficient vacuum in heavy traffic, but did you have any other issues?
    I am running a Rover 4.6l V8 with an LT77 gearbox and a competition clutch.
    Any advice would be much appreciated.
    Kind regards
    Rob
    Rob
    AK Gen I - 4.6l Rover V8, Stage III heads, MC1 cam
    On the road March 2019
  3. #33
    9,944
    Hi Rob, yes the higher the ratio the lesser pedal effort.
    If you have enough engine vacuum you'll be fine.
    It depends what cam you have.
    I ended up fitting a vacuum reservoir which helped.
    You will find a tiny bit of lag but not a problem you get used to it.
  4. #34
    Jun 2014
    Swansea
    108
    Hi Kev
    Thanks. I have an MC1 cam.
    I will probably go with the 1.9 ratio.
    Rob
    Rob
  5. #35
    1,042
    Measure your idle vacuum which should be around 12-15 ins/hg and you will be fine in traffic. Some high lift cams only give you about 5 ins/hg which is where you will have issues.
  6. #36
    Jun 2014
    Swansea
    108
    Will do.
    Rob
    Rob
