Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Heavy Clutch
    1,044
    Heavy Clutch
    Hi ,
    I need to lighten my clutch pedal as it is very heavy, present girling 625 bore with T5 box with thrust bearing dax pedal . I am looking at options . Pedal travel is very small at present to shift .
    1. Replace master cylinder 0.5 bore . Ford do a girling rally version. https://www.carbuildersolutions.com/...hout-reservoir
    2. Try and change the ratio pivot point . The master cylinder pedal . Does not look to be much room .
    3. Fit servo but the feel and loss of control is my worry
    I did notice that the angle of the piston at starting point is not straight but straightens as the pedal is depressed.
    8,529
    Going smaller will make it heavier, try going larger on the master size, 0.7 or even 0.75"
    1,269
    http://www.cobraclub.com/forum/showthread.php?t=55406
    The above link may help?? Thanks Lee
    2,339
    Are you sure? Smaller bore will shift less fluid for the same pedal travel and the clutch will move correspondingly less.
    9,944
    I agree with Myles, a smaller master cylinder bore will have less resistance but give longer pedal travel.
    I usually use a pair of 7/8" cylinders (0.875").
    In build- Hawk 289 Sebring
    1,269
    Tony is right, even if you go smaller bore on the pipe diameter, it's gets stiffer, you are trying to push the required volume to activate the clutch through a smaller orifice.
    There is a proven balance of master cylinder, pipe diameter and slave cylinder that works well, I know the master cylinder used is usually 3/4" or 0.75", tube bore if I remember and someone can correct me if I'm wrong is 3/8 the slave I can't remember! Maybe 7/8ths
    I still had a heavy clutch due to having a heavy duty pressure plate BUT the pedal ratio in the AK was nowhere near the 6:1 ideal pedal ratio.hence why I fitted a clutch servo and moved the pivot point.
    Lee
    9,944
    Agreed a smaller bore hose / pipe will give you higher resistance I always use -4 hoses. Some use smaller -3 brake pipe and get away with it.
    But I stand by a smaller master cylinder is going to give a lighter pedal than a larger one. (with the trade off of a longer pedal).
    It's simple physics about surface area and all that.
    1,269
    I used -3 at 1st but it was no good, it's achieving the best balance there is a lot of threads on here to search through. Some of it is trial and error but this method is costly.......like everything else with cobra' s!
    If you still need more help give us a ring thanks Lee
    Devon
    281
    Cobra 289 (Carlos) has a website with a spreadsheet - clutch calculations, which is very useful in working out how to get the pedal pressure you want.
    http://www.donostia.demon.nl/
    9,521
    I agree that a smaller bore master cylinder will move less fluid and lighten the pedal but you also say that there is very little pedal travel so a combination of a smaller bore master but an increase in the pedal travel sounds like a good direction to try.
