Results 1 to 9 of 9
    Nov 2006
    Shropshire/Wales Border
    5,955
    Jag Diff Flange Needed
    I seem to have been an idiot and lost the diff flange from my Jag diff and I'm getting set to get the prop made.
    Don't suppose anyone has one kicking around that they would sell?
    Lloyd B
    Nov 2006
    5,955
    Sorry, should say its the 4 bolt flange I need
    Lloyd B
    May 2014
    768
    Hi Lloyd,
    I have a Jag part prop-shaft end (with 3 bolt end needed to mate with Jag diff) for sale £25?
    Alan.
    AK Gen II on the road Jan '19
    Tremec T56 Terminator.
    3.27:1 Powr-lok LSD
    May 2014
    768
    Are posted at the same time, no good then!
    Alan.
    3.27:1 Powr-lok LSD
    Southwest, Somerset, U.K.
    35
    3,233
    I may have one from a completely shagged diff I took out of a car. Il have a look and report back.
    Nov 2006
    5,955
    Cheers Anthony, would be great if you have one.
    Lloyd B
    9,944
    If Anthony can't help I'll bet Russell can.
    In build- Hawk 289 Sebring
    Nov 2006
    5,955
    Russ was very helpful Kev.
    He advised that the flange is the same as a Defender flange. Just grabbed a second hand prop shaft that I can take one off on EBay for 99p.
    Cheers Russ!! Owe you one.
    Aug 2011
    353
    Lloyd,
    No problem.
    Just in case anyone stumbles across this thread in the future - Lloyd was after the prop (to diff) flange - common flange to most RWD British Leyland (GKN sourced) diffs from the 70's and 80's.
    Defender diff flange however, does not generally fit the jag diff unless it's specifically from the Salisbury (uprated) axle - the spline is completely different on the standard Defender pinion shaft.
