    Oct 2017
    Germany
    10
    Removing the body
    Hi guys,
    I want to remove the body of my SRV8. Already did download the SRV manual here, but didn´t found anything where the body has been fixed at the chassis. Does anyone has got an overview for me?
    Many thanks in advance!
    Alex
    144
    I myself have built an SRV8 ( 92 / 93 m y ).
    The G R P tub is fixed down with large self tapping bolts with large washers supplied with the kit .
    The process I used to fit the tub was :-
    1) Run a bead of P U windscreen type sealant on the inner & outer chassis rails (this was to eliminate squeaks / rattles etc) .If I needed to remove the body shell now I would have to cut the sealer with a cheese wire to enable its removal .
    2) Drill holes through tub into chassis rails.
    3) Fix self tapping bolts with washers through tub into chassis rails .
    Hope this is of some use,
    Regards,
    Chris1
    10,024
    It sounds like the body is bonded on as well as screwed down.
    Daxes are riveted and bonded.
    Personally I think you have a massive job on your hands trying to cheese wire through all that rubber glue.
    Do you really need to remove the body?
    In build- Hawk 289 Sebring
    144
    I myself have no need to remove the shell thank goodness .
    This was my idea at the time to carry out the process of using the P U ,nothing mention by Southern Roadcraft .
    I was quite pleased with the finished result of my build and have not had any creaks or groans ,although that could be disguised due to the S R side pipes !
    2,942
    I don't recall seeing anything in the build manual regarding bonding body to chassis (http://srv8stuff.sytes.net/cobra/SRV...d%20Manual.pdf)
    Not sure if ours is bonded at all.
    Gary
    Oct 2017
    Germany
    10
    My problem is that the body has been warped/welded (I don´t know if it is the right word) a little bit after the accident. Normally noone is seeing that but I do....
