Page 1 of 67 1231151 ... LastLast
Results 1 to 10 of 670
    Oct 2017
    Oxford
    560
    Classic Replica Build
    As a few of you may have seen, I recently picked up a pretty much unstarted Classic Replica's kit complete with donor parts from a Jaguar XJS V12.
    Here it is loaded up on the trailer last weekend
    Oct 2017
    Oxford
    560
    Yesterday I managed to spend a couple of hours sorting through the pile of parts from the donor vehicle
    Brake Calipers
    Front suspension/running gear
    Drive Shafts
    Alloy Fuel Tank
    Oct 2017
    Oxford
    560
    Rear Bottom Wishbones/Arms
    Oct 2017
    Oxford
    560
    I also have the following items - do these get used or are they replaced with substitute parts?
    Steering Rack
    Steering column, switch stalks etc
    Master Cylinder
    Brake Servo
    Oct 2017
    Oxford
    560
    I have the original build manual, not that it is worth much!
    It looks like the rear radius/trailing arms and front ARB are used in the build - is this correct?
    They are missing from my pile of donor parts, so if someone can confirm that would be appreciated as I will need to source these items.
    1,522
    Good luck and welcome to the growing number, albeit very slowly, of Viper owners! Remember Bob Busbridge of Cobretti is still in businesses. www.cobrettiviperv8.com
    Oct 2017
    Oxford
    560
    Yes I have spoken to Bob once already. I think phone rather than email seems to be the only way with him though!
    9,439
    When we built my mates car we didn't fit the trailing arms we just fitted bracing bars triangulating both the wishbones and then fitted one spring and shocker per-side. At this stage it is worth considering if you want dished rear wheels as if you do you will need to have the rear suspension shortened which some of the kit manufacturers could do for you I know AK & Dax used to do it. This will effect the offset of the rear wheels that you will need. We also fitted a smaller servo than the Jag one as it was way to big in our opinion the replacement was half the size and worked perfectly well. Good luck with your build.
    Oct 2017
    Oxford
    560
    Thanks Tinka
    I did wonder about the trailing arms. I think the Diff is solid mounted?
    I will probably keep the rear suspension standard
    Can you recall what servo your mate used?
    9,439
    Thanks Tinka
    From memory it was from a Mazda 323 although I can't remember what age it was.
