Page 11 of 77 FirstFirst ... 9101112132161 ... LastLast
Results 101 to 110 of 762
  1. #101
    Oct 2017
    Oxford
    616
    Brake servo/master cylinder and clutch master cylinder fitted
  2. #102
    Oct 2017
    Oxford
    616
    Everything had been stripped down on the Jag suspension components by the chap I bought the kit off.
    I neeed to rebuild the rear suspension with new bearings etc. This is proving to be a struggle as I did not take them apart so have nothing to draw on memory wise.
    First task is the Hub Carriers, I have fitted the new bearing races
    But now need to assemble the bearings with various washers, fibre washers, spacers etc. I have looked at various exploded drawings/views, but am still struggling to identify exactly which parts go where, or to put it another way an order of assembly. This is the hub carrier rebuild kit, but I cant work it out. Can anyone help with this?
  3. #103
    1,558
    Looking good. What was servo and master cylinder off?
  4. #104
    Oct 2017
    Oxford
    616
    Looking good. What were they off?
    What were what off?
  5. #105
    1,558
    What were what off?
    Sorry you posted again whilst I was posting a reply so edited to make clear.
  6. #106
    Oct 2017
    Oxford
    616
    The brake servo/master cylinder is from a Mk1 1.8 MX5
  7. #107
    Aug 2014
    York
    466
    Looking good and progress being made. The following site was helpful re. the rebuild of my hubs etc.
    http://dazecars.com/dazed/JaguarIRS4.html
    Also, the Jag service manual was invaluable. On the Dax chassis, there is a danger of the rear hub carriers bottoming out against the chassis on full droop. Removal (cutting) of “eye brow” shaped section on the inboard top edge of the carriers was advised. Might not be an issue for you with your chassis, but may be worth checking.
    Did you go with brand new front stub axles?
  8. #108
    Newcastle upon Tyne
    1,848
    Fuel lines fitted to the chassis
    Kind of hope I am wrong but shouldn't the nuts have been on the brake lines before they were flared? The build is looking really good, look forward to seeing it evolve,
    Regards,
    Ian
  9. #109
    Mar 2008
    Coventry
    2,298
    Quote Originally Posted by Ian C View Post
    Regards,
    Ian
    Yep, he has certainly forgot to put the nuts on before flaring the pipes
    AK, on the road Oct 2012
  10. #110
    8,513
    Nuts?? On fuel lines?? Are you mad???
