Page 3 of 111 FirstFirst 123451353103 ... LastLast
Results 21 to 30 of 1101
  1. #21
    9,537
    Thanks - he did not go for PAS then. Any reason you know?
    I have a Megasquirt in my Westfield, they are good bits of kit
    To be honest the steering was so good (after he had it professionally setup) it would of been a waste of money to fit power steering, but if we had then we would of fitted electric system from a Corsa.
  2. #22
    3,684
    Remember that you will need to show a collapsible column for IVA
  3. #23
    Oct 2017
    Oxford
    890
    Yep thanks, I know about the collapsible requirements for IVA
    What is a common column that gets used on new builds?
  4. #24
    Aug 2014
    York
    494
    Ford Sierra on Dax variants - non PAS.
  5. #25
    9,988
    Depending on the steering shaft angles you can often get away with the combination of knuckle joints that would deflect and a collapsible wheel boss.
    BTW the Corsa B EPAS works well in many applications.
    In build- Hawk 289 Sebring
  6. #26
    Oct 2017
    Oxford
    890
    Thanks - can you shed any light on what is needed for the Corsa B EPAS?
  7. #27
    9,988
    Just replied on your other thread.
  8. #28
    Oct 2017
    Oxford
    890
    So basically a complete column like this
    https://www.ebay.co.uk/itm/VAUXHALL-...19.m1438.l2649
    And a gizmo to trick the ECU like this
    https://www.ebay.co.uk/itm/Corsa-B-C...MAAOSwxGRZgYFb
    Is that right?
  9. #29
    9,988
    Basically yes and yes.
    Except the one you listed is a Corsa C not B column, similar but not quite the same.
    As you're probably going to have to make your own brackets it probably wouldn't matter.
    My controller is an automatic one which senses the load rather than having a twiddle pot.
    Try and get one that comes with the harness plugs too if you can.
  10. #30
    9,537
    Is that right?
    If you are going to run megasquirt then they have a module which will controll the power steering automatically linked to the speed you are traveling.Big Tony fitted this system successfully with his mega system.
