Page 41 of 47 FirstFirst ... 313940414243 ... LastLast
Results 401 to 410 of 463
  1. #401
    Oct 2017
    Oxford
    394
    Quote Originally Posted by drammyboy View Post
    Thanks for that KugaWestie.
    Where did you get the flexi pipes and were they special order?
    I had to drop the steering arm off from the hub to fit the banjo, but no big deal.
    I had them made up by https://furoreproducts.co.uk/
  2. #402
    Oct 2017
    Oxford
    394
    In preparation for putting the engine and gearbox back in, I fitted a load of cable tie saddles around the engine bay and down both sides of the tunnel to carry the wiring loom. All pop riveted on with a good blob of silicone in the hole first. Much easier to do now with nothing in the way!
  3. #403
    Oct 2017
    Oxford
    394
    I have been a bit busy today, but managed an hour tonight to do some reassembling.
    Alternator brackets, alternator and new vee belt fitted. The belt is a touch long, it will do for a start but needs to be about 10-15mm shorter
    The dipstick was next
    Then the starter motor
    Lastly I refitted the gear selector, mounting bobbins and bracket to the gearbox
  4. #404
    203
    Looks like real progress; keep it up.
  5. #405
    Oct 2017
    Oxford
    394
    Quote Originally Posted by skinnymathew View Post
    Thanks - I intend to, really enjoying it at present
  6. #406
    Oct 2017
    Oxford
    394
    While there is still room, I decided to weld in a total of 10 earthing point studs around the chassis in various locations.
    One under each back corner for the rear lights
    One under the fuel tank at the sender end
    One under the fuel tank at the pump end
    One each side in the front corners of the engine bay
    One each side in front of the engine bay in the radiator area for the lights, fan, horn etc
    Finally one each side at the rear of the engine bay in front of the tunnel
    I finished off by refitting the mounting brackets to both sides of the engine
  7. #407
    329
    I'd have taken the opportunity to mount the gear selector with solid bushes but that may just be due to a bad experience with rubber/plastic ones
  8. #408
    Oct 2017
    Oxford
    394
    They have all been replaced with brand new rubber ones so I am sure they will be good for a few years of limited mileage and dry storage
  9. #409
    40
    3,498
    I wish I'd added earth points and cable tiedowns before fitting the body to mine - well thought out, you can tell this isn't your first time to the rodeo
    I did chuckle though.. earth points, smothered in paint That must be that special conductive chassis paint...
  10. #410
    May 2014
    591
    IVA advice
    Kuga,
    You need to move this pipe, cannot touch and its also too close to the chassis mate.
    Otherwise looking good, enjoy buddy.
    Alan.
    AK Gen II delivery date Oct '15, IVA pass Dec '18
    GM Vortec LQ4 364ci
    Tremec T56 Terminator.
