Page 64 of 64 FirstFirst ... 1454626364
Results 631 to 633 of 633
  1. #631
    Oct 2017
    Oxford
    529
    Before starting to glass the body together I decided to see if I could get the radiator to fit.
    The first job was to make up a dummy
    Once I slotted it in behind the nose it showed up the problems, exposed in the bottom corners and generally too low
    I thought for a day or so about how to overcome this and came up with a plan to modify the radiator. So I tackled the dummy I had made by lopping off three of the corners and I managed to get it in.
    Here is the modified dummy. I will get the rad modified next week and also get some mounts sorted at the same time for the fan.
    Originally I had the fan mounted behind the rad, but in order to make it all fit it will now have to go in front of the rad.
  2. #632
    Oct 2017
    Oxford
    529
    With peace of mind that I could get the rad to fit I decided to start glassing the boot to the body
    I have started with just a few 2" wide strips to get things held in position
  3. #633
    245
    Not so much Cardboard Aided Design as Hardboard Aided Design. I like it.
