Page 65 of 113 FirstFirst ... 1555636465666775 ... LastLast
Results 641 to 650 of 1126
  1. #641
    Reading, Berks, UK.
    1,634
    Thanks, that’s useful information. I haven’t done much grp work before so this is going to be a journey!
    So far it looks to be air bubbles in the gel coat along the joint lines
    No probs, just get them out now, or once its painted the air inside will expand and you will get ringing and marks in the final finish.
    Just ask away, its a job to remember 40 years worth of doing this sort of thing, so easier to ask.
    David
  2. #642
    Oct 2017
    Oxford
    909
    David
    Thanks. I intend to do a very thorough job on the body before getting it sprayed for sure. From what I have seen so far it’s going to need a lot of work so I am sure it will teach me some new skills!
  3. #643
    Oct 2017
    Oxford
    909
    I need to make up some flat grp sheet. I was planning on using some MDF to lay it up on, and coat the mdf with some car wax first. Sound ok?
  4. #644
    Lanarks
    64
    472
    Car door glass - just did this today
  5. #645
    Reading, Berks, UK.
    1,634
    Try to avoid car wax, I have always used good old fashioned hard floor wax, couple coats polished off. If not look for some release wax, it's not expensive
  6. #646
    Oct 2017
    Oxford
    909
    I made up a mould and then laid up a panel to close the boot floor off to the rear section of bodywork. I have also made some end pieces. Everything needs trimming and then glassing together
  7. #647
    Oct 2017
    Oxford
    909
    The eagle eyed amongst you might have noticed in this post http://www.cobraclub.com/forum/showt...976#post586976 that the bonnet was not sitting flush with the body. This is because it was fouling on the air filter.
    I sorted that today
  8. #648
    Oct 2017
    Oxford
    909
    I trimmed up the boot panel I made as well as the end pieces, and then tiger bonded them together
    Once that had gone off I turned it over and glassed it together
  9. #649
    Oct 2017
    Oxford
    909
    No photos to show for it, but over the last few days I have been glassing the boot to the body. I completed this today.
    Very fumey in the garage even with all doors and windows open!
  10. #650
    1,209
    You must be high as a kite with all the fumes. Lol
