Page 73 of 113 FirstFirst ... 2363717273747583 ... LastLast
Results 721 to 730 of 1126
  1. #721
    1,209
    Might be of help if you go with the pilgrim ones.
    https://pilgrim-motorsports.co.uk/Ca...ion_Manual.PDF
  2. #722
    1,209
  3. #723
    Oct 2017
    Oxford
    909
  4. #724
    Lanarks
    64
    472
    Bonnet hinge and door hinge from round bar and flat bar with a few round tubes
    I found the Jag inner spacers were ideal for this application.
    Have a go and save some £££
    Like the idea from the previous post showing the video of bear claw latch installation.....
  5. #725
    Oct 2017
    Oxford
    909
    So after a nice sunny two week family villa holiday in Portugal done and a week back at work I am back at it.
  6. #726
    Oct 2017
    Oxford
    909
    I fitted my home made closer panel at the front of the rear arch on the drivers side and glassed it in
    Rear bulkhead glassed top and bottom on drivers side
    Closer panel viewed from inside the arch
    Last top area of the arch closed off
    Rear of the arch closed off to the boot panel on the underside of the car
    Finally the boot liner panel was glassed to the arch panel inside the boot area
  7. #727
    Oct 2017
    Oxford
    909
    That's the rear of the car all glassed now, very happy to close that chapter of the build off
  8. #728
    Oct 2017
    Oxford
    909
    I decided to see how the boot panel fitted. It was not much of a surprise to see it needed fettling!!!
    Drivers side
    Passenger side
    Front
    Bottom edge
  9. #729
    Oct 2017
    Oxford
    909
    I decided to attack the boot panel with the DA machine and a 120 grit pad.
    After about an hour of sanding, offering up, marking, re-offering etc, this is the result. It still needs work but at least it goes in the hole now!
    I think the next step will be to hinge it to see how it operates and then once thats done work on the gap lines to even them up.
    Drivers side
    Passengers side
    Front edge
  10. #730
    1,209
    You going internal hinges? The gaps look pretty good and you will not nee to do a lot of work. I have external boot hinges and think the strain on the fibreglass needs a metal plate on the inside which I will look to install.
