Page 74 of 113 FirstFirst ... 2464727374757684 ... LastLast
Results 731 to 740 of 1130
  1. #731
    Oct 2017
    Oxford
    912
    You going internal hinges? The gaps look pretty good and you will not nee to do a lot of work. I have external boot hinges and think the strain on the fibreglass needs a metal plate on the inside which I will look to install.
    I have got S and J external hinges
  2. #732
    Oct 2017
    Oxford
    912
    Having checked by bag of goodies I bought this year at Stoneleigh, it looks like I didn’t buy any boot hinges!!
    So I currently have options. Can anyone point me in the direction of internal hinges so I can decide?
  3. #733
    Oct 2008
    Horndean, Hants
    585
    There is a thread on here somewhere about fitting MG TF hinges which requires a bit of fabrication but obviously not something you would shy away from!
    Advantage is, they are self supporting so no rams needed.
    Bob
    AK GenII arrived 1st April
  4. #734
    1,228
    Thread for MG TF hinges. They do take up a lot of boot space. Also Hawk
    do a set.
    http://www.cobraclub.com/forum/showt...ghlight=hinges
    AK link
    https://www.aksportscars.co.uk/media...l-boot-hinges/
  5. #735
    Oct 2017
    Oxford
    912
    do a set.
    AK link
    Thinking further down the line, what do you use for rubber trim to seal the boot lid, bonnet, doors etc?
  6. #736
    May 2011
    Flimwell
    838
  7. #737
    May 2011
    Flimwell
    838
    I don’t think many people actually seal the bonnet. I have a series of small bump stops.
  8. #738
    Oct 2017
    Oxford
    912
    I was looking at this
    https://www.woolies-trim.co.uk/product/1286/door-seal
    Should be ok? Would I use this around the door apertures as well?
  9. #739
    4,212
    IIRC I had to use 'fin' profile seal for the boot, otherwise the boot wouldn't close (it made it stand proud) - ah yes, googling up the post I stole the info from, this one: https://phoenixtrim.co.uk/01-draught...etre-434-p.asp
    For internal hinges, I used the Europa ones: http://www.cobraclub.com/forum/showt...742#post574742
    It wasn't too hard to fab, but did take a couple of stabs before it would clear the rear deck properly. If I remember, the key was to have the pivot point 'higher' (closer to the deck skin) than I thought it should be, and closer to the opening than I predicted, to give the right arc. Happy to measure mine if you want to crib, and the fab skills are definitely within your realms if I can manage it
  10. #740
    Oct 2017
    Oxford
    912
    Thanks Aaron.
    I have taken a punt on a set of old MGB roadster hinges that I found on ebay last night for a tenner, so I will see how I get on with them.
    Is the general consensus to fit the boot panel first so it sits nice with the body and then look at the rubber seal after?
