Page 84 of 86 FirstFirst ... 34748283848586 LastLast
Results 831 to 840 of 860
  1. #831
    Oct 2017
    Oxford
    736
    I have got the passenger side of the car sanded now down the full length of the car. Lots of gelcoat holes have appeared which will need attention.
    I decided to take a break from the dust last night and started looking at making the bonnet fit properly against the body for height and also panel gaps.
    Firstly I fitted six rubber pads to bring it level with the body. This worked perfect at the front of the bonnet, but the back of the bonnet is still sitting a bit low. I intend to build the back of the bonnet up slightly with filler at the pad positions to bring it level.
    Then I took the bonnet off the car, turned it upside down and roughly filled the perimeter of the underside along the grp joint.
  2. #832
    Oct 2017
    Oxford
    736
    I spent some more time on the bonnet today, it's getting there slowly
  3. #833
    Oct 2017
    Oxford
    736
    Filling and sanding of the underside of the bonnet is almost complete
  4. #834
    Oct 2017
    Oxford
    736
    Adjustment of the bonnet gap at the front
  5. #835
    Oct 2017
    Oxford
    736
    Bonnet scoop front opening cut out done. The gap between the inner and outer skins need filling.
  6. #836
    Oct 2017
    Oxford
    736
    Whilst in the cutting mood, I did the passenger side vent. It still needs finishing and tidying up.
  7. #837
    Oct 2017
    Oxford
    736
    Final job for today was to fit the boot seal
  8. #838
    Lanarks
    223
    Another great update with good clear images.
    10/10 once again
    Just look back at what you have achieved in little over a year.
    This build will give inspiration to others that want to build a kit
    You have demonstrated welding, fibreglass skills and engineering solutions to
    various problems that you have encountered…. RESPECT
    Like others, I am looking forward to the next installment.
  9. #839
    Oct 2017
    Oxford
    736
    10/10 once again
    There are times when it goes a bit dark and it seems never ending, but I am determined to complete it
  10. #840
    Oct 2017
    Oxford
    736
    Some more pudding applied to the bonnet scoop cut out tonight.
    The gaps are all filled. Next will be sanding and shaping!
