Drive shaft uj JLM 1388 X4
INNER bearing CAC 6332 X2
INNER seal CBC 1706 X2
Outer bearing CAC 6333 X2
Outer seal CAC 8663 X2
hub nut CBC 7355 X2
SHOULD BE ALL YOU NEED CHARLIE
PETE
This winter I will be sorting out the play in the rear wheel bearings and the driveshafts. Any idea what part numbers are for the parts that I require. AK GEN2, Outboard brakes.
Charlie
AKCharlie - ''AKA SOOTY'' - AK GEN2 - LS3 - 6.2litre - 434bhp - A dream come true.
hub nut CBC 7355 X2
PETE
All the numbers you need, click through to your donor, find the parts and it brings up a numbered diagram. They don't stock everything but at least you know what to order.
https://www.jaguarclassicparts.com/uk
Hope that helps, Graham.
Thanks Pete and Graham
Charlie
