Results 1 to 10 of 12
    Jul 2014
    Southam, Warwickshire
    257
    How much brake fluid do I need to fill my system?
    Hi chaps, just looking to get some brake fluid to fill my brake system.
    Generally how much (and which is best) should I need?
    Thanks.
    Stu
    STOKE ON TRENT, U.K.
    10,118
    Depends how quickly you manage to get all the air out.
    A litre if you are lucky
    DOT 4
    ‚ÄčPro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Low Volume manufacturer of
    OEM style stainless SIDEPIPES
    Jul 2014
    257
    Thanks for the reply Dave. I'll probably get a little more then.
    Stu
    Nov 2013
    My Garage
    912
    Quote Originally Posted by Stu238 View Post
    Stu
    You will need more as firstly you will need to fill the reservoir up then you will need to keep filling it as you fill the piping and then bleed them out
    MKIII Pilgrim Sumo. 3.5 Litre Rover V8
    https://classiccartouring.com
    For Touring and Camping
    323
    You could make an estimation of system volume by adding up the volumes of the cylinders (presumably you know the diameters, approximate extensions and quantity?) and the reservoir. The pipes won't involve too much volume but should be easy to work out.
    Bear in mind when bleeding the brakes the aim is to get as much air out as possible (all of it) not to blast as much fluid through as you you can. If you do it wrong you could pump a bucket full through and still leave air in, do it right and only a small amount will be needed.
    Worth filling the system and leaving for a bit, air will naturally riee to the highest point and some will try to escape through the reservoir.
    Holding the pedal down 9vernight will not help to bleed the brakes.
    Jul 2014
    257
    Thanks for all the replies. Greatly appreciated.
    Looks like I'll do a quick calculation to get a rough volume and then get plenty more just to be safe . Just thinking about it I may give it a bit of a flush out too with a cheaper option fluid.
    As I will be doing this on my own has any one used something like the Gunson Eezibleed to 'make it a little easier'?
    Stu
    9,361
    You will need quite a lot more depending on how easy it is to get all the air out of the system, so no point in working out how much you need to just fill it. I found the cheapest way was to get a 5L bottle as this was about the same price as just over 2 x 1L bottles. Then just blead away and if for any reason you need to adjust anything in the braking system which introduces air in it you will still have plenty to rebleed the system. JMHO
    2,737
    i bough one of these a few weeks ago to do the brakes on the Mini after i'd replaced all the discs and pad and the front calipers - so much easier and little chance of getting air back in the system. Used a car tyre as the air feed/pressure source.
    https://www.screwfix.com/p/gunson-br...iece-set/33881
    well worth the outlay - and i'm a cheapskate - lol
    Gary
    Jul 2014
    257
    Thanks all. Great info as always.
    Looks like a 5 litre container and as Tinka suggested. Always better to too much and a bit spare. Also thanks Gary for the link to Screwfix for the Eezibleed.
    Purchases in hand .
    Stu
    Oct 2006
    Toton, Nottinghamshire
    779
    I replaced my front calipers and bled the rest of the brake system earlier this year. Definitely worth get yourself one of the Gunson pressurised bleed kits as Gary suggested. Makes the whole job a lot easier. I managed to get by needing less than a couple of litre bottles of Pagid DOT4. Always worth having extra if needed and you can use the same stuff to fill your clutch hydraulic circuit too.
    Russ.
    1984 DAX Cobra
