Thread: Loom Questions
    Sep 2016
    Newbury, Berkshire
    154
    Loom Questions
    Hi folks, fitting the loom now and have a couple of questions:
    1. Has anyone (is it recommended to) fit something over the split conduit to make it fully waterproof when run in the wheel arches?
    2. Any recommendations for grommets or similar (rubber tubing?) to protect the conduit where it passes from the engine bay into the wheel arches?
    Many thanks, Mike
    Jun 2014
    Norwich
    64
    307
    Ran all mine inside the car except out to headlights at very front end
    but still covered in self amalgamating tape to make sure
    Aug 2014
    York
    476
    Not an AK, but on my dax I ran the front loom under the o/s bonnet lip using p-clips and s/s dome headed machine screws. Also, check out Project Tango in the GD section. Chap called Steve ran loom through conduit in the wheel arches there - there’s photos too. ECS has some deep grommets that were perfect for the scuttle hoop firewall. HTH
    Feb 2010
    Essex
    235
    Corrugated black flexible conduit similar to this on my AK, I used for the main battery cable run in the rear wheel arch.
    https://www.screwfix.com/p/tower-cor...ails_container
    Barry
    Sep 2016
    Newbury, Berkshire
    154
    Thanks chaps, most helpful...
    Oct 2014
    United Kingdom
    51
    347
    Heat shrink tube is an essential bit of kit for all wiring - comes in all sizes and colours and makes a professional finish.
