    Jan 2015
    Paignton Devon
    191
    Fitting the engine
    I'm planning to put my engine in shortly, it's a rv8 into a sumo, might seem a basic question but should I do it with the lt77 gearbox attached or join them afterwards?
    Roger
    1,899
    I fitted mine together, drop them in with the gearbox lower than the engine.
    Drop the gearbox into a trolley jack and it roll up the transmission tunnel.
    Top the gearbox oil up first, it’s a bugger to get at once it’s in.
    Jan 2008
    Basingstoke
    975
    Yep both together. Jacking up the front end a bit makes it easier too.
    Jan 2015
    Paignton Devon
    191
    Thanks chaps, that's what I thought but you never know what problems others have come up against so I thought I'd ask
    Roger
    Dec 2001
    Cherval, France
    1,650
    Sorry to disagree with Alex, but jacking up the rear helps, not the front !
    Also try and beg steal or borrow a load leveller which will allow you to tilt the gearbox down to start then bring it up as you lower the engine down to the mounts.
