    Jun 2016
    Nantwich Cheshire
    52
    276
    Harness and Battery cable Grommets
    I’ve been trying to source some grommets for my harness and battery cables on my AK.
    I was going to order some from ECS which are suitable for 5-6 mm panel thickness.
    Unfortunately they are out of stock.
    After doing a bit of trawling around I’ve found something suitable, see attached pic.
    Unfortunately they only come in packs of 100 and I only need half a dozen or so.
    I was just wondering if anyone is else is interested buying some.
    I was thinking of buying 100 and splitting them up into packs of 10.
    Works out at £6.50 for 10 grommets including postage.
    Let me know if you’re interested.
    If I can get half a dozen people or so I’ll order some and post them out.
    Mike.
    Feb 2008
    Rayleigh Essex
    10
    Mike,
    Apologies- we are experiencing problems with the section on our website that deals with grommets, however the wider panel size grommets can also be found in Cable, Battery Cable and then click on any of the Battery Cables and you will find them as one of the accessories. Here is a link to the grommet I think you are looking for. If you need any further help please let me know-Martin
    https://www.electricalcarservices.co...8-170-448-2387
    Jun 2016
    Nantwich Cheshire
    52
    276
    Hi Martin,
    Thanks for the link. I can find the grommet on the site but it still says out of stock and won’t let me add it to my basket.
    Mike.
    Feb 2008
    Rayleigh Essex
    10
    Mike,
    You should be able to order now.
    May 2011
    Eastbourne
    I started out using grommets but found nylon cable glands much less fiddly, they have a threaded plastic lock nut so they don't slip out, they grip the cable but you can loosen them off if you need to re do anything. They look loads better and you can have different colours ie red for your battery cable. I also use them where hoses and fuel pipes pass through metal. 50p each from RS or Screwfix.
    Jun 2016
    Nantwich Cheshire
    52
    276
    Cheers Chaps,
    I have now managed to order some from he ECS site.
    If I Struggle I might give the cable glands a try.
    Mike.
