Results 1 to 10 of 15
    Mar 2010
    1,243
    Halfords battery conditioner fooked
    Happy new year Gents and hope you all had a wonderful festive season.
    As the title says, I have had a Halfords 12v/6v battery conditioner for a couple of years and today thankfully whilst I was in the garage I noticed a burning smell and traced it to the battery conditioner connected to my AK. On closer inspection it had started to melt in one corner so disconnected it and threw it outside to cool off (thank the stars I was in the garage, because it usually sits in the boot!!).
    Whilst not being happy at this failing after only a couple of years, I am understandably nervous of purchasing another one of the same ilk and wondered if there is a particular tried and tested one out there that will be more reliable?
    Many thanks.
    Paul.
    Mar 2009
    liverpool
    403
    Hi I've been using a couple of Ctek mxs 5.0 for a couple of years, one connected most of the year on a boat with no issues. They have attachments for quick plug and lights on the connectors showing the state of change when it's not connected. Phil.
    Mar 2005
    1,085
    Following advice on here a few years ago I have a smoke alarm in the garage just in case something like this happens.
    David (AKA Firestarter29)
    1,610
    I’ve heard the Ctek has a good reputation. Do you need to disconnect the battery when charging? I’ve only used a conventional charger then I do disconnect.
    Feb 2016
    Scotland
    481
    ctek mx5
    I leave the battery in situ but turn the isolate switch to off ( like removing 1 lead )
    Just going out to smell the garage
    Jon W
    Oct 2006
    Toton, Nottinghamshire
    862
    As others have said, the CTEK chargers are 'the daddy' according to all the reviews etc. If you fancy a cheap alternative, Lidl have a charger as one of their 'specials' from 11th January. Price is 13.99. I've used the Aldi equivalent for a few years which looks same, albeit a different case. Mine has a maintenance charge facility on it so I suspect the Lidl one may have too. I haven't left the Cobra connected on the maintenance charge only because my garage isn't hooked up with mains power (unless I run an extension cable from the house).
    I disconnect the negative lead from the battery and connect the charger direct to the battery terminals.
    Russ.
    1984 DAX Cobra
    Aug 2009
    URMSTON,MANCHESTER
    460
    yes CTEK for me too been using for about 4 years now, on more or less all the time and not once has it let me down, highly recommended,
    Gary.
    Mar 2010
    1,243
    Thanks for the advice guys, have ordered a CTEK conditioner.
    I consider myself extremely lucky to have been in the garage at the time and averted........well Indread to think!
    If you one of these:
    Be be very vigilant and make sure it will not burn anything else should you experience the same fault.
    Sep 2014
    winchester
    40
    https://accumate.co.uk/cg040001.htm Very good maintainer/chargers. Have used them for years.
    2008 GD Euro Mk 4 427. LS2 with cam upgrade= lively
    Mar 2017
    Alton, Hampshire
    65
    Hi Phil,
    I have used Ctek for about 4 years and have only good things to say about them. I have one on a car most of the year and another on my Cobra which is connected and disconnected regularly.
    When you purchase the unit it arrive with small croc clips and a pair of leads which can be bolted onto the battery and then the unit can simply be plugged in via a single connection. The extra money is well worth it.
    Cheers, Jon
    Jon LR
    Magnum with Ford 302ci & 4 speed Toploader
