Results 1 to 3 of 3
    Jun 2005
    Norton Cross
    425
    Dashboard wiring
    Hi All,
    Been putting this task off for a while but can't put if off any longer.
    I'm starting wiring my dashboard and a bit confused about the best way to go about it. I'm using Smiths flight gauges.
    The AK manual says to daisy chain some of the wires - is this the best approach?
    Anyone got any pics they can send?
    Also, if i need to extend some wiring - would 8amp cable suffice?
    Pete
    May 2014
    613
    Smiths flight wiring
    Hi Pete,
    Yes you "daisy chain" all of the grounds, illumination and power for the Smiths flight gauges, I used Black for ground, Red for illumination and Green for gauge power.
    excuse the mess this was taken pre-tidying up.
    8 amp is more than enough if you need to extend.
    Just make sure you connect to a decent ground if you end up linking the switches an maybe a cigarette lighter socket.
    Alan.
    IVA pass Dec '18.
    On the road Jan '19
    Tremec T56 Terminator.
    Jun 2005
    Norton Cross
    425
    Thanks Alan. Going to have a go at wiring it up on the weekend.
    Pete
