    Apr 2012
    Wrexham
    566
    Xj differential breather cap
    Hello,
    Whilst under the car doing bits, decided to check oil level in the diff. Its a powerlock 3.54 one.
    Oil wasnt level with plug so topped up and decided to put some more in through round black breather cap, just another 20ml or so with syringe. Only thing was when i prised the black cap off i didnt see which way the insert under it went? Anyone removed this?
    Dont want to get it wrong way around incase it does not vent properly...
    Any ideas?
    Gav
    AK Ls1/t56
    Body on April 2014
    Passed IVA March 2017
    Registered April 2017.
    Marlow
    69
    1,851
    Don't overfill the diff! I ruined one of my early track days, oil from a hot diff sprayed out over the inboard brakes . Not a good idea!!
    Cheers Clive
    Jan 2009
    blackpool lancs.
    5,093
    Bad move!, sorry dont know about the vent, but thats what the fill plug is for, oil comes out of it when its full
    Apr 2012
    Wrexham
    566
    Thanks for replies.
    I will remove the fill plug again and let it spill out then until level.
    Still dont know about breather cap thpugh....,
    Gav
    AK Ls1/t56
    Body on April 2014
    Aug 2011
    363
    'T' shaped inner breather fits into the pipe then the little plastic 'springs' inside the main cap keep it 'shut' and in place flat side faces the outside world. Acts as a one way valve allowing fumes out but shuts under vacuum stopping you drawing in water and cr*p if you dunk the diff when it's when hot.
    Apr 2012
    Wrexham
    566
    Aha,
    Was hoping you saw this.
    Many many thanks Russell
    Gav
