Results 1 to 9 of 9
Thread: Engine Crane
    Jul 2013
    Hertfordshire
    522
    Engine Crane
    Does a standard engine crane have a long enough reach to drop a Chevy 350 into a cobra from the front. The one I borrowed to take the engine out was a really old style one and it was about six inches too shoer. Ok to remove engine as it just swang back but no good putting it back in.
    9,536
    The one I used was too short and I had to remove it from the side.
    Oxfordshire
    68
    1,643
    It's fairly easy to extend the boom and the legs by inserting lengths of box section. Doing this, and with the use of a balance bar to adjust the angle, I was able to install the engine into my Dax De Dion from the front.
    Alan
    Jan 2015
    Paignton Devon
    377
    Mine is too short, remedied it by buying a longer piece of box section to extend it, just make sure you get a piece long enough to go all the way to the back of the section it slides in when extended, obviously using it like that will negate the warranty but it should be fine for the weight lifted
    Oxfordshire
    68
    1,643
    A good point, which I should have mentioned too! A short extension will put all the stress on the last part of the boom rather than the entire length. Note that when loaded up this will move the centre of gravity forward, so you also need to extend the legs to prevent toppling. Even then, I recommend a second person to assist if it starts to tilt forward, which is quite easy to do if operating on a rough rather than a smooth surface as you roll it forward. Also, that will make the base of the crane wider so I fitted spacesaver wheels to the front of the car to gain some extra wiggle room for the crane legs.
    Alan
    Jul 2013
    Hertfordshire
    522
    Thanks all. They do cranes with extended reach so that may be the way to go.
    Nov 2006
    Shropshire/Wales Border
    5,982
    Must admit, id not buy an engine crane again. PITA. Never enough reach or lift, plus the legs always seem to be where the axle stands are or where you need to get underneath the car.
    If I was starting over with buying an engine removal thing, I'd consider instead some form of bolt together gantry on castors or a beam in the roof with a sliding winch.
    Lloyd B
    Jul 2013
    Hertfordshire
    522
    I totally agree Lloyd however as we are selling the house and I need to get the car back on the road ASAP I just need a quick fix. The place we are hoping to buy has a triple garage to would put an hoist in on rails
    2,934
    not sure if these guys have an engine crane that's suitable or not? good service when i've purchased stuff from them in the past
    https://www.sgs-engineering.com/gara.../engine-cranes
    Gary
