Results 1 to 4 of 4
    Dec 2013
    Flackwell Heath
    86
    Battery isolator
    When using an Omex system does it make any difference to battery isolation ie, the build manual shows the earth going through the isolation switch which is how I was going to do it but thought I ask the question as it's easier change now!
    comments appreciated
    Mark
    AK gen2 ls3
    2,127
    My Omex worked just fine with a battery isolator on the earth, no issues.
    Having said that, I’m just using quick release battery terminals on the next one.
    2,127
    When you bolt the bracket to the chassis, make sure it goes into a threaded hole, a nut and a bolt won’t give you a good enough earth path for the starter.
    Dec 2013
    Flackwell Heath
    86
    Thanks for the replies Craig! Electrics aren't my thing and I was concerned about doing some damage to the Omex, relays on the power side and I had no idea if you'd get a power surge/ spike
    AK gen2 ls3
