Results 11 to 14 of 14
    Feb 2014
    Derby
    162
    Cork ones ordered see how it goes
    cheers Ian
    Dec 2005
    leeds
    197
    Quote Originally Posted by Youngy View Post
    cheers Ian
    Sorry for the late reply Ian. Yes rover on the bottom and what ever the pattern is to match the adaptor plate and cover
    9,400
    Quote Originally Posted by Russ-Notts View Post
    I've tried putting the rubber Rover gaskets under the adapter plates. They're too flexible and just squeeze out.
    Russ.
    The trick I have always found to work is to assemble them with a layer of silicone on both sides of the gasket but not to do them up more than finger tight until they have well and truly gone off, then finish doing them up at least 24ht's later. Never failed me. This is for the adapter plate, on a normal rocker cover or sump gasket I would do one side at a time but the same basic process.
    Mar 2005
    BERKSHIRE
    612
    i got a pair of offenhauser on a rover v8 with no adapter plates
    real steel had a batch made or got hold of sets to fit the rover in the early 90s
    rare as hens teeth ,,,,and no i don't wont to sell them as many have asked me
    Hi all is anyone out there running with Offenhauser valve covers on a rover v8 with any success I’ve herd they fit with no adapter plate .?
    many thanks Ian
