Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
Thread: IVA overriders
    44
    2,283
    Quote Originally Posted by Peaches94 View Post
    Hi Craig, I can’t remember if front or rear, but the gauge the tester used was small enough to check both ends.
    ps. If you are off to Kidderminster remember to check seat base to top seat belt anchorage dimensions.
    I've already failed on that once at Kidderminster, for me it was all about where the seat belts come through the headrests.
    His gauge might be small but if he can't touch it with the head sphere, he shouldn't be measuring it. Problem is, if I remove the rear bumper I've lost fog, reverse light and reflectors.
    Nov 2016
    Stevenage
    48
    274
    Cant seatbelts come through the high back slotted headrest seats then?
    225
    No need to cheat when you can comply.
    These will be painted blue to suit the bodyshell.
    I thought about vacuum chroming them - but that costs £
    225
    STOKE ON TRENT, U.K.
    10,163
    Quote Originally Posted by drammyboy View Post
    Sorry to be the bearer of bad news, but these look like they will fail.
    Where your insert meets the edge of the over rider there needs to me a minimum 5mm radius. It looks like and angle from the pics.
    A bit of knock on edging strip would have done the trick.
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    Low Volume manufacturer of
    ALUMINIUM BODY, ROUND TUBE CHASSIS.
    ORIGINAL SPEC. SUSPENSION COBRAS.
    OEM style stainless SIDEPIPES
    225
    Awe naw..............
    225
    Quote Originally Posted by dave View Post
    but you advocated removal of the overriders and bumpers to pass the test
    I'd appreciate a photo of the 'friendly' IVA overriders
    You know the ones with the smooth back or those with the wee radius
    10,163
    But you said "Why cheat when you can comply"
    I don't use over riders too often these days.
    The rear nudge bar is good for hanging the extra lights and reflectors from for the test.
    I use the same nudge bar as you have with the flat mounting plates.
    Where the over rider goes I just fit dome nuts
    Pro Cobra Builder
    DB427SC
    DB REPLICAS
    Find us on Facebook
    db427.com
    225
    I also said that I'd NEVER built a Cobra for the current IVA test.
    I presume you have built several for the test or have all of yours had the overriders been fitted after a pass was recorded?
    Can you show the IVA 'friendly' overriders please.
    You know the type- those with less than 1/4" radious.
    and yes....hanging off the rear lights makes sense.
    I'm looking at moving the fog lights a little closer to the overrider but still making sure
    there is 25degress visable. I do hope this is OK with the tester.
    641
