    Sep 2014
    Wales
    321
    Front and rear end set ups
    For those of you with Rover V8 power and Jag suspension in your Cobras, what have you set the front and rear suspension geometry at (toe in, caster and camber) and how does it drive?
    Cheers...Nige
    3,457
    For which make of Cobra?
    T56 Gearbox
    3.54 LSD Diff
    AP Vented front brakes
    Outboard X308 Vented rear brakes
    Sep 2014
    Wales
    321
    All makes
    Feb 2013
    180
    Thing is, different manufacturers' chassis can have the engine and box mounted farther forward or rearward, which would potentially change the settings you request. I would like to know the settings for a Rover V8 powered Dax...
    DAX Cobra MK3 chassis, MK4 shell. RV8.
    Feb 2006
    Somewhere in Kent, I think?
    5,589
    Hi Bannon. 1993 Dax build manual says:
    Front track 1/16" toe-in
    Front castor Max possible but equal each side. ie if you get 3o on side and only 2o the other set both sides at 2o.
    Front camber. 7/8o +/- 1/8o
    Reartrack 0 to 1/16" toe-in.
    Rear camber 1o negative.
    As an example of course........
    Ian DAX 454 Chevy
    It's not shabby!............. Just has a highly developed patina! My Gallery Take a look.
    Feb 2013
    180
    Thanks for that, Slogger. Very useful - I'll keep that for future reference.
